G2 44+ PSU fault
Hello everyone,
Hope you're getting along ok in these difficult times.
I've been getting what seems to me to be an odd PSU fault for the last week (G244 with 2 x powered RIOs).  In the unset state the keypad will randomly go into the alert state with the dreaded beep. On inputing the master code the screen shows the following fault:
AC Fail PSU 103
which I assumed to be the PSU on the second RIO unit (103=3rd PSU after main panel?) but now not so sure.  On opening all 3 panels all would appear to be fine inside with the red LED in the RIO units flashing at the correct rate.
I installed the main panel back in 2011 which has been flawless and the 2 RIOs early this year and they've both been fine too.
Any ideas from the Galaxy experts here?
Many thanks,
Richard
Edited by Driller
  • Replies 31
  • Views 7.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • have you considered buying a dog ?
  • Reassuring to know it's not just me James! Swapped out just the power supply bit after removing the ribbon cables. It was fully compatible with the existing RIO main board and problem solved immediate
Posted Images
6 minutes ago, Driller said:
Hello everyone,
AC Fail PSU 103
Many thanks,
Richard
I am definitely not an expert lol
But seen these throw up a fault , how have you wired up the power lines ? From the panel what did you wire to the PSU rio
Have you got a dog?
If its reporting ac fail on 103 I'd start there. Measure ac side and dc side. Asuming that's all OK id assume a smart PSU failure
Could be the smart RIO PSU card (one on the right) if its the newer switch mode PSU, seen a few with a dodgy capacitor.
www.nova-security.co.uk
www.nsiapproved.co.uk
Thanks for the suggestions (and Mr Happy's inimitable input ;-)). I'll be able to get a tester on it tomorrow and see what it says. Cheers Nova for the heads up on the cards.
We have had a few of the new switch mode power supplies fail over the last couple of years.
causing no end of problems.
Possibly C4 / C7
