G2 44+ PSU fault
  • Replies 31
  • Views 6.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • have you considered buying a dog ?
  • Reassuring to know it's not just me James! Swapped out just the power supply bit after removing the ribbon cables. It was fully compatible with the existing RIO main board and problem solved immediate
Posted Images
1 hour ago, sixwheeledbeast said:
That's why they use so much leccy...
Does SW sell lightning conductors? ?
4 hours ago, Driller said:
There's a flux capacitor?! ?
Agreed did you check the flux capacitor? Easy when you know how , or you need pictures?
I would love to have a picture
Edited by Driller
Gentlemen, I now have a battery failure on that powered RIO module (of course) and only 9V on the board which makes sense.
All the right lights are on (flashing red on RIO) fixed green on PSU (I removed the shroud).
Can someone who knows please confirm that I need to replace the PSU module?
Ps forgot to say I have 220V measured coming into the PSU
The SMPS will be likely be blown like above.
You can't test more than in and out unless you open and they are not designed to be user serviceable.
You could try power cycling everything and a new battery but most likely you need a new one.
Thanks SWB, so can I get hold of just the SMPS part or do I have to replace the whole thing?
i was supposed to leave to go on holiday today, Sod’s law. Any way I could rig up a 12V 4Amp supply in the SMPS’s  place temporarily?
i guess the RS 485 bus would throw up an error if I did that.
  • 2 weeks later...
For anyone encountering a similar problem, got a new powered RIO but will just try swapping out the power supply part at first.
