May 5, 20206 yr comment_500382 Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 5, 20206 yr comment_500387 2 hours ago, AgsDave said: Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500387 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 5, 20206 yr comment_500388 I assume if shows open its needs a resistor or link in the terminal too Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500388 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr comment_500398 Is it well old? Might need a restart if the circuit was in use, then went fault before spared off securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500398 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr comment_500408 Airitechs need to see a 4k7 EOL even if the circuit is programmed as unused. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500408 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr Author comment_500451 I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. 19 hours ago, al-yeti said: You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal No it wouldn't set. I prefer galaxy all day long. But I guess it's what you get used too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500451 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr comment_500452 Only ever serviced a couple of Aritechs never made any changes, didn't know that about resistance req. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500452 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr Author comment_500453 4k7 alarm and tamper. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500453 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr comment_500460 2 hours ago, AgsDave said: I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. Airitech need the 4K7 EOL if the zone isnt used, not like a Galaxy where you can spare it with nothing in the zone www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500460 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 6, 20206 yr comment_500463 On the older ones there were 2 attributes called unused. Never remember having to put resistor in unused cct Edited May 6, 20206 yr by abbz Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43783-aritech/#findComment-500463 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
