Aritech
Anyone know why a zone programmed as unused still shows as open when trying to set?  I'm sure it's a simple thing, but not a panel I am familiar with.
You mean it's alerting you? Or on zone status when checking before setting?
Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal
I assume if shows open its needs a resistor or link in the terminal too
Is it well old? Might need a restart if the circuit was in use, then went fault before spared off
Airitechs need to see a 4k7 EOL even if the circuit is programmed as unused.
www.nova-security.co.uk
www.nsiapproved.co.uk
I did fit an eol to solve the issue.  Just wondered if it was something I had missed in the programming.
No it wouldn't set.  I prefer galaxy all day long. But I guess it's what you get used too.
Only ever serviced a couple of Aritechs never made any changes, didn't know that about resistance req.
Airitech need the 4K7 EOL if the zone isnt used, not like a Galaxy where you can spare it with nothing in the zone
On the older ones there were 2 attributes called unused. Never remember having to put resistor in unused cct
Edited by abbz
