Odd though wasn't it?
"Hello, welcome to Gardiner Technology , we've got Gardtec panels, Novagard bells, Gardtec PIRs, Gardiner Technology 1.5" screws... oh and, I know this won't interest you, we also sell DSC"
1/2 dozen Napco DT's & one of those nice internal SAB in the speaker case
  • Like 1
19 hours ago, sixwheeledbeast said:
Why not run your own cables and get a small decent approved company to fit some decent kit? Not saying all companies would all be up for that or that they may want some disclaimer about existing cabling faults, but worth asking.
Fitted a few DSC in the past for an integration job, specced by a HA company.... Uses an interface with a serial bus so the HA can see all the devices live, the rest was all done on the HA side. It was just weird foreign tat IMO nothing special.
All these North American panels are just not designed for the UK market, they may work as an alarm but not conform and support will be limited from manufacturers and installers.
JW listed most of the usual UK market panels, Galaxy Texecom Eaton etc. Have you actually decided if your DIYing or not because that's the first step really. Talking manufacturers is useless if your still thinking your getting someone in.
Everything is already run, I've run all the sensors many months ago when we had a lot of work done, alone with probably 50 Cat6 :D
I'm going with the Dimension or Flex, just deciding atm.
14 hours ago, MrHappy said:
Domestic property of a certain risk - proper alarm with proper signalling, jewellery / watches  Faberge eggs or whatever kept in safe of certain type.
AMCO, you appear to want something cheap, they appear to have no approval for any of their scope of works.
ADT ect..., if going to take days to fit , I assume over a grand just for the man hrs
Konnected, again looks cheap & cheerful,
Envisalink -  looks cheap & cheerful...
DSC - I believe they've fully withdrawn for the UK for a number of years, I thought they where pants...
The out the box solution is texecom ect & control4 ect...
Wired alarm in a bigish house couple of grand, control4 much much dearer
I be happy to instruct any of my cleint's to do the wiring, however depend on who & what I may want paying to do so ;)
I've already run all the cables, no issue there.
No I don't want something cheap, I talked with AMCO because they offered the ability to add their equipment alongside one of these boards that I may add on. ADT, no thanks, the rep who came out was a complete *****, excuse my french.
Again I think the discussion around monitoring company went off topic too, I did some research but AMCO were the only ones who seemed interested in helping, and another firm in Knightsbridge I can't remember their name.
If my insurance company is happy with them as a monitoring station I don't see the problem if their services work. Happy to hear feedback but everything online seems positive, more so than ADT.
Also happy to hear other suggestions for South East monitoring.
Edited by sg86sg
Gone for this kit:
  • C005-M-E2 - Flex 20 Panel v3.1 Firmwar
  • CP050-00-01 - MK8 Keypad
  • CP037-XX - MK7 Keypad
  • A083-00-01 - Ethernet Module v3 firmware
  • A073-00-01 - RF Portal v3 firmware
  • A081-00-01 - GSM module
28 minutes ago, sg86sg said:
Gone for this kit:
What will you use the GSM module for? Cheaper to run the selfmon I reckon through the network card , get more for your money
Flex 20 will be to small for you judging by how you talk flex 50
I thought the GSM module was for backup for dual path signalling is that not right?
Can you expand on what is too small about the flex20? Im not using the door control and only have a 5 bed house so tbought it would be ok as it says for medium size businesses!
1 hour ago, Logan said:
Can't you use a touchcenter with the flex 20
Stick to the sterling dude
Ok I understand
I forget your going with an arc
Ok I understand
For price difference flex 20 for someone who wants to make it do more you will have less hassle having a bigger panel later
I would definitely putting contacts on all the windows in your house aslong as you pay up
Easiest way is wireless in this case
Register a new account
Sign in
