Texecom NVM Locked Panel
16 minutes ago, MrHappy said:
Do you remember uncle frank ?
Run around....
G g g g g go
8 minutes ago, Logan said:
@MrHappy is this your enforcer.  It got your company name on it
The time gives you away...
  • Replies 40
  • Views 20.8k
6 hours ago, BrianClark said:
Had a locked panel recently and just couldn't get into it to default it.
So ended up making a utility to do just that.
Annoying when a company locks a panel then decides to go bust lol.
Option 9, cant see how that would work when you cant view the codes on the panel. Or does your tool display them
www.nova-security.co.uk
www.nsiapproved.co.uk
Rich I assume its a post to get pm's. But as I don't know the panel
9 hours ago, Logan said:
Im only used to
Castle caretech euro series
Ademco galaxy 16/90
Scantronic Ion30EXD
Scantronic 9100, 9200, 9500, 9600
Texecom veritas
ADE XM, XL, compact 6, compact 6+, g3, g4, accenta 6/8/mini
Good start really , as plenty of those about , and gives you basics of panels
Edited by MrHappy
Probally, would be good tool for some engineers
'Currently - Using Personal messenger'
Didn't realise this was so active !
Some of you guys are on after midnight, thats a bit hard core lol
Option 9 to set random passwords was kind of for testing. Just so I had something "non default" to prove that the "back to defaults" was doing something.
Although I guess it gets past that problem where every company uses the same engineer code malarkey...
My sympathies to Al-Yeti, I also work with Scantronic panels lol. Damn things have been added to so many times over the years that you're jumping back and forth looking for the correct code sequences.  Still, makes life interesting - and at least these can be defaulted easily! :D
16 minutes ago, Logan said:
Well TSI comes before sleep
Yeah, sleep is for woosies anyway lol.
