Omnicron 8000 24 HOUR LIGHT On since decorating
Hi guys,
I've got a omnicron 8000... When I decorated I removed the front face of one of the detectors in the front room and ever since I've had the 24 hour light on constantly. With this I can't set the alarm as it goes to go off everytime I press reset. Please help don't just tell me to bin it lol
The lid isn't on the front room sensor properly.
Also if you haven't had it serviced recently you will likely need a control panel battery at least, if the rest is working. Alarms do need regular maintenance.
37 minutes ago, Frappo1988 said:
Hi guys,
Plastics can crack up aswell so be gentle dude , if you break then you can chuck it otherwise feel free to keep lol
Sweet guys thanks very much. I'll pop him off again tomorrow because there's a spring inside that maybe has to be placed a bit better. I'll let ya know how I get on :) thanks again
OK, it's a brilliant panel, the best of it's kind even back in the day, has no doubt been scrupulously maintained and is a shining example of how a 30 year old alarm really isn't tat fit for the bin.
Will that do?
Edited by datadiffusion
Will that do?
1 hour ago, Logan said:
False my grandmothers frend still has a optimia XL6 installed and works fine. But i do service it
an XL6 won't be 30 yrs old ;)
 omnicron & the other a1 panels where very much a diy / sparky new build product
Please rate us on TrustPilot
23 minutes ago, Logan said:
Just like response?
mostly wired, IIRC they lock up & stop working
1 hour ago, MrHappy said:
mostly wired, In BT cable
Which is weird because alarm cable was cheaper than BT back then
