Problem with Safe Alarm
Hi. We have recently taken over a Manor home and in one of the rooms is where the guns are stored. However every time we open the gun safe to get it fitted out for our equipment the alarm keeps going off even though we though the alarm is not set it's becoming a pain now!!! Could anyone please advise me what I am doing wrong? I will try and insert some pictures.
Edited by Davawirral
  • Replies 38
  • Views 8.4k
  • You need a key for the zone omit unit above. Once you have it omit the zone (it will buzz) open the safe, close the safe and un-omit the zone.
  • Does the omit unit buzz when you turn the key? You may need a code for it also/or
As above the devices are on 24 hour alarm, you need to use the key to disable the alarm first.
I've found the key and turned it on the box above the gun safe but when I open the gun safe door it still goes off and when we silence it at the keypad in the office it displays Gun Safe Door. Surely there must be a way around it I need to store the guns in the safe cheers
1 hour ago, Davawirral said:
I've found the key and turned it on the box above the gun safe but when I open the gun safe door it still goes off and when we silence it at the keypad in the office it displays Gun Safe Door. Surely there must be a way around it as its apart of the police licence to ensure all guns are kept in a secure lockable safe cheers
No it. Doesn't make any noisy which ever way I turn the key the alarm still goes off. The only noise it makes is if you press any of the numbers!!!
Call me crazy...
Did you get in touch with the installer / maintainer of the security system & ask them to train you on how to use the alarm correctly ?
Maybe when they undertake the maintenance visit, update the kekoholder ect...
1 hour ago, MrHappy said:
Call me crazy...
That will cost money tho?
Call me crazy...
It was already installed when we took over the building we have all the keys to the safes and the alarm unit above the gun safe and we also have some key fobs for the keypads by the front door and office and landing.
