Gardtec 840 removing smoke alarms from panel and program
1 hour ago, al-yeti said:
Yes it does lol
Make zones unused or spare , then flaff around with it and hop you don't blow a fuse or something
On a side note put linked smokes and you can still link it to the alarm
Doing above means you can remove all of them leave cables as is , protect all the ends incase you have them put back
And then fit whatever junk you want
Probably cheap £4.99 battery only detectors, he's already said that he's on a tight budget so they sure won't be Mains / Battery & seriously doubtful that they'll be linked.
  • Replies 60
  • Views 10.6k
  • datadiffusion
    datadiffusion
    Bugger me I'm getting old   When I first discovered t'interwebs a username containing 'red dwarf' usually denoted a spotty 15 year old herbert   now its the mark of a penniless pen
  • Reddwarf4ever
    Reddwarf4ever
    Sorry that answer didn’t really address my concerns   Hi   i have the engineer,installation & user manuals, so will be able to remove the required zones, although if anyone kno
  • sixwheeledbeast
    sixwheeledbeast
    Why remove them if they work? Surely it would be more sensible to replace them if you need. Alarm company are unlikely to be impressed if you remove stuff, you also risk the possibly of having no
200 pennies per hour is cheap
Stop blagging
£200 an hour is cheap ? :o. I seriously need to change areas, down here they bitch at £45.00 callouts.
5 hours ago, al-yeti said:
Haha he didn't notice
Top house basher. Get it right al, Bungalow basher if you don't mind:whistle::).
Yep I noticed, just thought you'd maybe made a mistake ;).
Edited by Specialist
Sent a long reply, which I assume needs moderating before it’s posted.
have contacted a different alarm company, who helped me out some years ago when the PSU failed on the main board and a repair was made.
he is coming Monday, £75 + VAT for an hour, which he said will be ample time to remove the zones and remove the wiring from the alarm panel......job done.....I am sure it’s not beyond me, but can’t fund the option in engineer mode to remove the zones, so will bite the bullet and pay to have it done.
thanks for all the advice....
Why are you disconnecting the original smokes ?. Really makes no sense, are they causing problems or have some failed ?.
You really are downgrading your fire protection by a huge amount. Hope for your sake you don't have a fire.
You can actually buy a half decent spec smoke detector that's compatible with most alarms for less than £15.00 each.
16 minutes ago, sixwheeledbeast said:
Still missing something here, why disconnect them in the first place?
Quote he has probably is costing more than standalones, so he probably thinking get rid them as he doesn't want extra ones on ceiling , then goes buys £5 smokes which still works out cheaper all the smokes plus the £75+vat , than having them replaced, system tested and so on
Edited by al-yeti
Brexit
