Castle omega 5 wiring help
Also the tamper return will be pos on that panel
  • Replies 29
  • Views 8.7k
  • Never heard of brooks before internet, thorn was finishing off as I was getting going... IIRC
Im guessing there was an especially made sab module that would go with the panel?
SCB where designed that way.
Tamper return will be +ve if the HO is +ve, you can see the tamper link is still fitted
9 hours ago, Jack b said:
Anyone out there know how to wire up a bell box sab to a omega 5 panel?
You try the phone number? :ninja:
Hmmmmmm no but i might just give it a try
I thought SCBs were the ones that had the voltage going directly to the bell box and when the alarm sets off, the hold off is cut sounding the bell using its own battery and SABs were the ones that had the trigger voltage?
You mean scb mode uses internal battery to activate sounder and hold off is just charging
And sab mode draws power from panel hold off when bell activated
Both have a separate trigger
Or something like that
Yep
Self Contained Bell, uses it's own lead acid battery to sound the siren when triggered from panel.
Self Activating Bell, uses the panel voltage to sound the siren when trigger is low, or "hold off" voltage is removed which "self activates" the bell from it's NiCd. Many modern SAB's have a SCB style mode.
You'd find SCBs in chubbs, AFAs, brocks and all that and you'd find SABs in thorns, Abels, modern alarms, etc.
