CARETAKER46 Posted January 23, 2018 Author Share Posted January 23, 2018 Soot mark may be the screen cover , when you buy new, as I did not take this off. I am returning the speech only Dialler and he will send me the speech and text Diallers and it is costing me more in postage returning it twice, I should of bought it locally for all the hassle I have to go through, fitted twice and now I have to take it off , so power off and take battery out and take it off the wall. This is the reason I need a Text option to be sure the message gets through I'm thinking txt is better, This is just to call a friend or Family member who will be key holder when I'm working away a lot out of the country and it could dial his mobile but if no answer and its answered by voicemail will the message be lost due to normal answer message and speak after tone ......i.e will speech just start straight after answer and could fail to be recorded by voicemail? Hence I'm thinking txt is better and just send to mobile just to be on the safe side. I wanted both options speech and Text, just in case they don’t answer or missed the call, so the text will be more better chance as a back up , if the caller is missed. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473475 Share on other sites More sharing options...
james.wilson Posted January 23, 2018 Share Posted January 23, 2018 if you want to be sure the message gets through you really don't want a dialler or text securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473476 Share on other sites More sharing options...
al-yeti Posted January 23, 2018 Share Posted January 23, 2018 28 minutes ago, CARETAKER46 said: Soot mark may be the screen cover , when you buy new, as I did not take this off. I am returning the speech only Dialler and he will send me the speech and text Diallers and it is costing me more in postage returning it twice, I should of bought it locally for all the hassle I have to go through, fitted twice and now I have to take it off , so power off and take battery out and take it off the wall. This is the reason I need a Text option to be sure the message gets through I'm thinking txt is better, This is just to call a friend or Family member who will be key holder when I'm working away a lot out of the country and it could dial his mobile but if no answer and its answered by voicemail will the message be lost due to normal answer message and speak after tone ......i.e will speech just start straight after answer and could fail to be recorded by voicemail? Hence I'm thinking txt is better and just send to mobile just to be on the safe side. I wanted both options speech and Text, just in case they don’t answer or missed the call, so the text will be more better chance as a back up , if the caller is missed. If you want both doesn't make sense from one device and doesn't make sense no gsm Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473478 Share on other sites More sharing options...
sixwheeledbeast Posted January 23, 2018 Share Posted January 23, 2018 1 hour ago, CARETAKER46 said: This is the reason I need a Text option to be sure the message gets through I'm thinking txt is better, We have already explained this. Both are poor as regards security however, speech is slightly better if your using a landline as your not relying on a third party TAP service. If someone cuts your telephone line, which is likely in premeditated burglary your not going to get any messages anyway is the point. As regards the soot marks, Mr. H is pointing out how old the panel is and hasn't been serviced in a while. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473480 Share on other sites More sharing options...
CARETAKER46 Posted January 23, 2018 Author Share Posted January 23, 2018 Hi James, So you are recommending to buy another Product like GSM Standalone , so it depends on the Sim card and no worries about the cable being cut. Dear Al Yeti. Understood your message, so i need the both Dialler and Separate Text GSM standalone and the franz.com Opentap will be No good , if the Bt cable is cut, so not text message or call. Hi SixWheeledBeast Ah Soot mark on the Veritas R8 panel you are talking about, just cleaned it, as i was installing the Dialler, but not had it serviced. What do i need to have it serviced, as it looked all ok to me. I never knew you had to serviced the Alarm panels. I thought it was cars, Boilers and bike i have this serviced, but never knew about the Alarm system. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473483 Share on other sites More sharing options...
al-yeti Posted January 23, 2018 Share Posted January 23, 2018 If the panel supports line fail to a programmed output or has pins you could have a gsm module that will also ping you that line has failed but it will ping every time Think about costs , if you paid a monitoring company to do all this they would notify you anyway But there are monthly costs from that way some cheap some expensive It maybe your a enthusiastic diyer then I recommend you just do what your doing Problem will be in finding a cheap enough contract SIM like max £5 per month unlimited sms Ps James I reckon is pointing to having a monitoring station and maintainer Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473484 Share on other sites More sharing options...
CARETAKER46 Posted January 23, 2018 Author Share Posted January 23, 2018 Thanks Guys for your reply. Thank you Al-Yeti for your information and Knowledge- 5 star to all the guys who have advised me and help me- really appreciated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473486 Share on other sites More sharing options...
al-yeti Posted January 23, 2018 Share Posted January 23, 2018 17 minutes ago, CARETAKER46 said: Thanks Guys for your reply. Thank you Al-Yeti for your information and Knowledge- 5 star to all the guys who have advised me and help me- really appreciated. Five stars of expert advice from others on TS, I I am a amateur lol Hope things work out Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473487 Share on other sites More sharing options...
MrHappy Posted January 23, 2018 Share Posted January 23, 2018 overloaded hence the little soot marks around the panel Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473488 Share on other sites More sharing options...
CARETAKER46 Posted January 23, 2018 Author Share Posted January 23, 2018 What does TS means ? is my Panel overloaded, I never had any problems with the panel or Alarm since 2004/5 i never noticed the soot, I will have to investigate where the soot is. Just a curiosity, even if I used another company to monitor my Alarm system, if the burglar cut my home Bt line, would the monitoring company know or they see a Bt line gone Faulty and try and contact the owner on thier mobile phone , which is registered to them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41877-texecom-speech-and-text-dialler-text-not-working/page/4/#findComment-473490 Share on other sites More sharing options...
