Texecom speech and text Dialler , Text not working
35 minutes ago, CARETAKER46 said:
is my Panel overloaded, I never had any problems with the panel or Alarm since 2004/5
yes, it also looks like it was wired in the dark by blindman
  • Replies 53
  • Views 16.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • being our resident texecom nerd....   How old do you reckon that  cheapest made in china  "awarding winning technology" battery is ?
  • little soot marks around the endstation ?
Posted Images
if its proper monitored comms yes you would be notified of a line cut. Doubt the risk warrants g4 comms but trying to avoid you feeling a false sense of security.
id never use a dialler for anything
Thanks James .
soot meaning is there a burnt mark, getting me worried now.
What is wrong with the wiring , so I can rectify.
2 hours ago, CARETAKER46 said:
Thanks James .
Just tidy it up a bit
  • 4 years later...
On 23/01/2018 at 22:05, CARETAKER46 said:
Thanks James .
It's a common problem with all texecom veritas panels with the voltage regulator    it doesn't even have to be overloaded for it to get very hot    I never seen one that has not had this problem   its just the design flaw all of these have
Just make sure to replace the battery and check the charger
Edited by Imnotshankled
Thanks i usually change the battery when it can not hold it any longer when the power cuts happen. Which Charger i need to check ?
Make sure you get around 13.6 volts on the battery leads
Thanks.
so i need to have 13.6 volts reading on the battery.
Is this without connecting to the panel ?
no it needs to be coming out of the panel so meter the leads with the battery disconnected.
Waiting till the battery has totally failed will usually kill the panel
