Hi, have old Challenger 5 home alarm system in house, worked a treat last 20 years, power cut the other day and it's went haywire?! Code no longer works and it just sets itself off... Trying to get user manual if at all possible pls??
Edited by john.lightbody
  • Replies 25
  • Views 14k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Oh dear "Jock McTightSporran" is asking a forum which mainly populated alarm monkeys why their employed.   What goes wrong with your simple house alarm?   Well there will be at lea
  • Duff battery due to lack of routine maintenance etc has probably knackered the charging circuit and the pcb, it's had a good innings though!-more luck than anything else I would hazard a guess.
  • I think its a stripped back version of the C+K Active 5 , sold through Wickes in the 1990's.
Posted Images
I assume it needs a service and a new battery, that's if no ones looked at it in 20 years.
Not been serviced, never had too, worked splendidly for all these years. Has had just 2 battery changes and the current one is dead, but since power cut last week once power came on it set off, code not working to turn off....
look gardtec ish ?
power it down,  restart it with no battery it if doesn't start with all the tampers close & fuses intact its knacked
I thought that g3xx looking
Do you service your car?
no, no point it worked fine for years till it broke, I did put new batteries in the remote tho
but I doubt anything is trouble free at that age, security systems are expected to work for ever with no tlc. What else has the same?
true, but you dont expect one to protect you and yours. Its a recurring thing, its been great for years but I didn't know id need it etc
