Circuitry of Alarm Panel Outputs and Inputs
1 hour ago, datadiffusion said:
It actually pretty much does look like an excursion it's so bright!
Libyan supplied?
  • Replies 31
  • Views 11.5k
  • sixwheeledbeast
    sixwheeledbeast
    I'd say all looks correct but the SCB return should be in TR not NC (which I assume from the diagram to mean "No Connection" and not "Normally Closed") As for the electronics behind the panel I h
  • Swb must be talking in general as each manufacturer can make there outputs different
  • Have you done it and what's the issue ?
Through PJ's China connection
2 hours ago, datadiffusion said:
Through PJ's China correction
Through PJ's China erection
1 hour ago, petrolhead said:
Its designed to give intruders leukemia.
And half decent service engineers
A half decent service engineer wears lead lined pants just in case.
Cos of bandits or the plutonium?
Never had you down as a gambler?
I work in glasgow, lead isn't enough to defend from the bandits you need a kevlar/buckfast weave too.
On 8/11/2017 at 10:11, al-yeti said:
White leds show up good in the day though...
At night time, the LEDs are quite good. Not sure whether  brightness increases when in alarm state though?
