Wireless zone expander problem
  • Replies 28
  • Views 8.8k
  • Thank you for all the constructive comments, so glad I'm posting in the DIY section and not passing myself off as a professional installer.   Maybe it's because I'm posting in the DIY sectio
  • Your controls are a bag of shit which don't meet any std, blunt but true...
  • james.wilson
    james.wilson
    Jk Do you fully accept liability for what you have done, or did you assume you have no liability cos you did your customer a favour. Id agree that members (including myself) can say things s
I'll add an update just in case anyone else is going to use a UR2 for this purpose.
Thanks to simlec's input it's all up and running. Either SET terminal within the G4 panel can be used, J3 switches to neg & J9 shwitches to + upon arming so can be used to arm the UR2.
Make sure you run 8 core originally or you'll end up adding 2 cores!
UR2 is easy to set up once you've learnt to use their comic strip instructions.
Just out of interest, how does the UR2 signal jamming, supervision, and battery notifications?
Probably needs another zone on the panel and another output ,
But then this geezer is stuck with what he put in
(Probably another 3 if we're going to argue:))
Just wondered as it has a 7 segment display, but not obvious from the spec exactly what this shows other than numerical zone activation (which I assume you can turn off).
Edited by datadiffusion
You have the tamper/fault output on the UR2 which you can put on a spare zone or wire in to the global tamper.
And wouldn't THAT be fun on an LED keypad panel at 2AM!
Still if you need upgrade great idea, bit they missed is a remote display or less or something
Great idea if you have plenty of spare, programmable (+ pref. ability to be non-siren at 2AM 'technical' zones) IMHO.
For all the future hastle better off just upgrading panel to same as your wireless choice, can't be much extra by the time you've splashed out on devices + RX (I assume universal RX dearer than expander).
Doesn't the Euro Mini handle a single Pyronix expander?
