Veritas R8 SW+ output
Really? I was wondering why it wasn't like that in the first place....
3 hours ago, MrHappy said:
Just ensure the alarm is audible from outside the final door normally achieved by using =<£5 extension speaker.
Using final exit to set, alarm would go silent when set ?
  • Replies 21
  • Views 9.3k
I can only just hear mine, rkp's only...
It's quite an old/complex setup for this one so the control box and rkp aren't where they need to be (extensions built, etc) so they're nowhere near the actual exterior anymore, relocating wasn't an option but adding a speaker to the right location should do the job nicely.
Thanks again for everyones input, appreciate all the angles to look at it from :)
personally I'd ditch the old controls & put a hybrid euro in.
press II & see status of the alarm.
If they can afford extensions they can afford some proper controls
I think we all know that security comes somewhere after the monthly bacon-by-post subscription in terms of necessity for most...
2k for the install then .......
You can get bacon, by post?
Given it as an xmas present - a years worth by overseas relative. They know me too well...
You can get a pack for a quid by signing up then cancelling same day.
https://www.cureandsimple.com/get-started/
Wow!
Major consideration obv's...
Really depends on the dog, in our testing, we found some dogs would chew the packaging regardless of what deterrents we used. The bacon is vacuum packed, then packed in an envelope and then an outer envelope keeping delicious aromas to a minimum, with the deterrent then added we believe all reasonable steps have been taken to prevent the bacon being eaten prior to reaching the pan. We would love it to be fool proof, but unfortunately we can't guarantee that your dog will not chew your tasty post.
Any selfish bastard that leaves their dog alone all day doesn't deserve bacon.
Depends, that's why we've got two, plus it's actually very rare we are both out all day. I would never leave a dog literally on it's own.
In our old house they could even go outside through a dog flap, I'm working on that at the moment as the new place is a bit different.
Hard to say if the packaging works as we've got one of those stupid Victorian letterboxes, so the postman just leaves everything in the porch.
Edited by datadiffusion
