Mixed wired/wireless alarm
I currently have a wireless alarm at my house (whole thing was £100 from B&Q) and after 6 months the battery in the siren has gone. I would go wired however we have plastered and decorated nearly every room in the house so don't want to be cutting into the walls. Is there any reasonably priced alarm systems that have wireless door and pir sensors with an actual wired siren? Can cope with changing batteries in the house but getting up a ladder (and I don't do heights) twice a year is a no for me! Thanks
  • Replies 58
  • Views 11.2k
  • james.wilson
    james.wilson
    you made a full recovery?
  • when I ten I'd probably be reading comic or making an Airfix kit,   In fact I got an F1117 Stealth fighter for Christmas     Getting a decent finish on the invisable pain
  • Understand I will pay more than £100, at the time it was all I could afford and next door had just been broken into. I did what I had to do.
Your sales patter needs a bit of work imo.
cheap tat from B&Q and youre surprised its gone flat within 6 month? im surprised it has lasted 6 month.
some wireless alarms can have wired bellbox & detectors but you can expect to pay a bit more than £100..
Unfortunately, you have fallen for the buy cheap buy twice. When you were in B&Q did you notice that they were not using the cheap tat they sell to protect their premises? I would advise that you take it back as it is less than a year old but as batteries are a consumable I think they could argue that you must have used all the battery power.
Just take it back if you the reciepts say it's not fit for its purpose you never know might get credit note or exchange for another item
You want to diy or have it fitted
Diy like pyronix enforcer kit ? Has wired bell option and wireless bell which lasts more than 6months but no comfort LEDs that are bright enough to noticed , has gsm and dialler options
Or texecom which has a great diy helpline , texecom ricochet system harder to setup imo
Expect to pay £500 plus for diy once you add on bits on and Upto £2k installed if you have a complicated setup
Sounds good eh?
Would want to DIY it as I am "fairly" competent. Thanks for the suggestions, one alternative are there any wireless alarms which use solar panels to keep the siren charged without changing the battery or is it pointless? Thanks
professional grade wireless sounders will do 2 years but it does depend how often you set it off. Pretty much all decent gear allows for a wired sounder.
