Floureon CCTV home system power supply issues
27 minutes ago, Simon maddox said:
What should I do?
Become Batman & fight injustice ?
or try a different telly / vga or composite video input ?
Log into its webpage & select a lower HDMI resolution ?
  • Replies 47
  • Views 19.2k
  • Become Batman & fight injustice ?         or try a different telly / vga or composite video input ?   Log into its webpage & select a lower HDMI resolution ?
Some sort of factory reset button or hardware switches on the back to change output?
It's Floureon it's a pile of junk that none of the trade members here would use or know much about.
It will have display settings in the menu, but you need to plug it in to  a tv with a higher resolution in order to get to the menu. I would do that before buying a new TV you may find you just have a dodgy HDMI lead or DVR
Sounds like Pete has a Floureon system at home ;)
Ive got piles of old tat that Ive ripped out and replaced, I use it to demo the rubbish over the good stuff  I counted 20 different brands from Anke to Swann in our test room, many have the same pcb different firmware
Yeah yeah
You are wonderful
I look up to you and think you are great
Whereas I look down at him....
