October 10, 201610 yr comment_451060 The power supply unit (PSU) carries out a number of tasks. a) What is the actual value of the regulated supply voltage that it provides to the system? b) What would be the influence on that voltage at the detection devices that are powered by that supply if the detectors were to be installed at an extended distance from the control equipment? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 10, 201610 yr comment_451064 a. Ideally 13.69 but that is now 13.75 as most diag cant hit that resolution b. Ohms law depends on the resistance and the distance. Resistivity is what matters. If the course is up to date id assume you discussed copper vs cca securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451064 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 10, 201610 yr Author comment_451065 Thank you very much for your help Sir. So basically that means over extended distance voltage will drop is that correct ? Edited October 10, 201610 yr by caveo security Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451065 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 10, 201610 yr comment_451076 yes it will. The more current you pull the more the volts will drop. No current = no vd. If you pull a load then you need to think about it securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451076 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 12, 201610 yr comment_451141 Why don't you do basic electronics course first? It will teach you this stuff Then house bash dot com Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451141 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 12, 201610 yr comment_451150 https://www.amazon.co.uk/gp/offer-listing/0860208095/ref=tmm_pap_used_olp_sr?ie=UTF8&condition=used&qid=1476265557&sr=1-1 I'm not joking OP - if you are struggling now you'll thank me later So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451150 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 17, 201610 yr comment_451551 When I did my course, i did it on site and one thing that come up was that maybe everyone should do the basic/ohms law course first. I think it was being put forward as a suggestion. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451551 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 17, 201610 yr comment_451569 My experience is that the majority (maybe being a bit unfair, but certainly a lot) of engineers don't know how to use their multimeter effectively. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451569 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 17, 201610 yr comment_451572 3 hours ago, norman said: My experience is that the majority (maybe being a bit unfair, but certainly a lot) of engineers don't know how to use their multimeter effectively. Next your be telling me it's not a door stop, I did a access course at Tavcom and the guy i was paired with seemed keen to guess the fault that was put on the test rig rather then using his meter, I like using a meter do the tests look at what you have. Then you can make a correct diagnosis. If someone asked me what tool i could not be without it would be my meter, Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451572 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 17, 201610 yr comment_451581 Mine would be my fleshlight. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/40523-psu-tasks/#findComment-451581 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
