Texecom LCDP 'keypad locked!'
Evening all,
I've gone to go out and arm my texecom system today, however when pressing 'area' to quick arm, the keypad produces a long beep and says 'keypad locked!' I have tried pressing yes and no down together to unlock the keypad, but it doesn't seem to work. Wintex works fine though. Will it be a case of power cycling the panel or am I overlooking something?
cheers
Keypad lock is built in to the keypad AFAIK.
Maybe a button is stuck stopping you from unlocking it?
1 hour ago, sixwheeledbeast said:
Did I miss something?
The OP said Yes and No.
Doesnt always work correctly by pressing at the exact same time, I always demonstrate to customers by keeping YES pressed in, before pressing NO
the early ones work, later ones need your trick
I was quite close to using a brick to unlock it! But thanks PSE, the trick worked!
always done yes and no, rather than at the same time hold down yes and no.
only other lock is a code lock which should reset its self after x hours, but don't get many of them.
Brick is always useful in your tool kit....lol
Edited by secureiam
