Strange Premier 88 Problem
enasecurity
Evening all,
I have a premier 88 that was purchased new but only installed 6 months ago in replacement of my old menvier panel. It has been working flawlessly since today...
It seems like one of the zones is stuck in walk test mode. When the zone is opened the keypad and internal speaker produce the walk test/fault tone. I have been on the phone with texecom and tried unprogramming the zone, entering and exiting walk test, powering down the panel....everything! And it still seems to be stuck. The system still operates fine though.
Has anyone else come across this problem? It seems very strange!
Thanks
i wouldnt say its a problem thats general. You dont have a smoke detector in that area do u?
I have no chime zones setup. I have rebooted the panel again and it seems to have sorted it. Texecom mentioned going into udl/Digi options and pressing yes 20 times. Does this do a soft Restart?
Thanks again
Thanks again
Suppose that one way to get people off the phone...
That is Reset Digi, I assume.
If you have no chime zones then it maybe be something odd.
Take a backup with Wintex and default the panel, try from there to rule out hardware issue.
Texe installers, is this a real command?
I've had a handful of premiers with "sticky" zones
You program it to "X" but it behaves as "Y"
eg- walkthough zone that goes into alarm during entry, (& when you check its deffo programmed correct)
program it off, come out of engineering. Go back & put it back to walkthough & its fine
I've experienced the same thing with other panels (either a optima+2, 9800 or TS790 forget which or maybe all?)
