Contact Working Opposite Way
MJE
Hello All
quick question that I cant find anywhere
can someone confirm that door contacts are supposed to be "closed" when the magnet is attached
I have a galaxy intruder panel i'm installing and everything is set up apart from the door contact as its working in the opposite way i want it to
it is saying door open when closed and only sets if the door is open
it has the supplied EOL resistor across it  (1K) and is set to 1k in the panel
I cant find any option to change it in the panel, i know it will be so something so obvious just wanted to make sure before i buy another contact
thanks
You can get them normally open. Have you metered it?
Is that a single resistor?  It should have 2 fitted typically if each sensor is on its own circuit.(1 inline with the door reedswitch and another across the reed switch)  If you have installed only the 1 resistor 'across' it then with the door open it would show tamper and stop you arming, but with the door open it would show healthy and allow you to set.  Just a thought.
