Adi Posted May 6, 2012 Share Posted May 6, 2012 anyone using rain x as standard on cctv systems? Just for domes or all cams? Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
Alpat Systems Posted May 7, 2012 Share Posted May 7, 2012 (edited) anyone using rain x as standard on cctv systems? Just for domes or all cams? Taken from rain x website... Can it be used on transparent plastics Generally no. The increasing variety of various coatings applied to plastics makes it impossible to pre-test for compatibility under all conditions, and users should satisfy themselves by treating an area outside the normal area of vision. Please note that constant, repetitive use should be avoided due to the possible formation of stress cracking, especially on clear, curved sections We've witnessed this first hand on a takeover. On-site maintenance had reported hairline cracks on the PTZ dome covers. When questioned turns out they where using rain x several times a year. Edited May 7, 2012 by Alpat Systems 1 Quote Link to comment Share on other sites More sharing options...
Adi Posted May 7, 2012 Share Posted May 7, 2012 Cool, thanks for that. Would you on metro housings though. Quote I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
aetherica Posted August 18, 2012 Share Posted August 18, 2012 (edited) Some (box) CCTV Camera housings are equipped with wipers. I wonder if there are any for Dome Cameras . Anyone knows ?.. Edited August 18, 2012 by jameswilson No contacts in posts Quote --------- CCTV Aetherica - Surveillance & Security Solutions --------- Link to comment Share on other sites More sharing options...
Oxo Posted August 18, 2012 Share Posted August 18, 2012 None yet. What Security Solutions do you do? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 18, 2012 Share Posted August 18, 2012 No as it coundnt work. I have seen specialist cameras that spin an outer some to repel water. But if its an issue you need a camera with a flat glass to use a wiper. Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 18, 2012 Share Posted August 18, 2012 But if its an issue you need a camera with a flat glass to use a wiper. Interestingly I just found this, which seems a very clever solution. Quote Link to comment Share on other sites More sharing options...
PSE Posted August 19, 2012 Share Posted August 19, 2012 If youre still after something to clean the dome plastics, Give this a try, (Meguiars Plast R-X Plastic) We have used it on a few dome plastics and it works a treat, I keep a bottle in the van for servicing, !! Remember !! Test a small area first, I aint gonna be responsible for fooked covers Quote Link to comment Share on other sites More sharing options...
Rulland Posted August 19, 2012 Share Posted August 19, 2012 T cut-original. Quote Link to comment Share on other sites More sharing options...
PSE Posted August 19, 2012 Share Posted August 19, 2012 (edited) Little bit of info about the product I posted earlier; (Meguiars Plast R-X Plastic) This easy-to-use, rich gel formula quickly restores optical clarity to both rigid and flexible clear plastics. Cutting-edge advancements in Meguiar’s® exclusive Microscopic Diminishing Abrasive™ Technology (MDAT) remove light oxidation, chemical degradation, surface contamination, stains and light surface scratches with ease. In addition, because the microscopic diminishing abrasives breakdown as you use them, PlastRX Clear Plastic Cleaner & Polish is safe on plastic rear windows on convertible tops, aircraft windows, motorcycle fairings, face shields, headlights and taillights, instrument panels, all clear plastic boat surfaces and aquariums. Meguiar's PlastX also contains highly water-resistant polymers. These specialized hi-tech polymers provide long lasting durable protection to keep your clear plastics clear and beautiful longer. Edited August 19, 2012 by PSE Quote Link to comment Share on other sites More sharing options...
