  1. Past hour
  2. I wonder what the traffic lights are all about. Never had you down as a Habitat shopper, always imagined you shopping in Morrisons
  3. Yesterday
  4. Every time I see this I think must share it as somewhere
  5. Last week
  6. Thank you and oh no the evil mod team lol
  7. 4700(496383_iss_1).pd Gotham postcode ?? oh noun..... attached appear to be from the grey workshop manual.... download it quick before the evil mod team remove it
  8. Ankle tag & 7too7 curfew ? Nah am living in a abandoned hospital my mate bought though Its so old the only manuals i can find are in French
  9. Ankle tag & 7too7 curfew ? is it listed in the grey "workshop" manual, as the product is much older than pdf files ?
  10. I'm pretty sure the guy has tried this but I'll get my mate to have a look with me and give it a try myself. Thank you for your help.
  11. To put that in english: Type the user code that works, press no till you get to CD press Yes then enter the four digits you want to use, and again a second time to confirm
  12. this shows the process
  13. Both the engineers code and the default user code allow me to access the control panel (the box that enables you to activate / deactivate the alarm) however as far as I can tell by the user manual I have, neither codes allow me to change the alarm set / unset code which is personal to myself. It must be able to be changed as it was changed when the system was installed in the property.
  14. If you have no code that works then you wont be able to change the code. If you could change the code without knowing what it is to begin with, anyone could just change your code while your back is turned.
  15. I have used the default user code and I don't get anywhere. There seems to be no steps in the manual to personalise your alarm code.
  16. Allot has changed since your release.... Eagle is same tho, I think...
  17. Im back after 3 years Was wondering if anyone had the installer manual for a scantronic 4700 never seen this panel before and cant find any information on it
  18. Jack b
    Internal of the 41A
  19. It sounds like the panel may have defaulted, you need the default user code rather than the engineer code. I dont know the panel but would guess the default user will be 1234 or 0123 or 4567 or 2222 or similar. There is not alot of info in the user manual and the panel is very old and obsolete
  20. I had a code that works but since the battery has been replaced it seems to have factory reset and I can not work out to add my original code back on to the system. Sorry for posting links, I thought they might help someone to understand what I've got as regards a manual.
  21. Earlier
  22. “Customer is always right” Nope, customer is a buffoon and doesn’t listen
  23. **adjust veil & looks into his crystal ball** Client won't manged the sim & should he get robbed or something silly happen like the place flood & the ceiling falls down & sets the alarm off when he's a 3 week cruise....... you'll be right **** for not selling him proper monitoring. 3 yrs signalling via wifi to an ARC will be cheaper than speech dialler ?
  24. I have the same problem the bell test and strobe test all work correctly. And when the alarm is activated the bell doesn’t sound on the outside but the strobe works fine. Can you help in correcting this
  25. Blow torch has been a thing for a long time?
  26. Yes he’s been given all the options but as he’s stuck in his ways he doesn’t want to use an ARC because it’s an ongoing cost and it’s not “how it’s always been since it was installed and it’s all BT’s fault blah blah blah”
  27. Shattering glass quicker and quieter if you know how
  • Who's Online   1 Member, 0 Anonymous, 58 Guests (See full list)
    52,049
    David R
    David R
    446.5k
