bob2611 Posted Sunday at 19:21 Share Posted Sunday at 19:21 The alarm in my house is just not working. The spanner light is on and I am unable to reset it. The system is about 10 years old. I replace the battery on the unit as I thought that was the issue. No luck. It will let me enter numbers but none of the other buttons will do anything other than give the sound suggestion it's the wrong action. As I said, if I put the master code in, it's not taking it. I would be very grateful if anyone help me understand the issue? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/ Share on other sites More sharing options...
james.wilson Posted Sunday at 21:34 Share Posted Sunday at 21:34 A decent quality battery would be an improvement but if it's not been serviced correctly and on time the psu is probably shot. You could try power cycling it but at least put a decent battery in it securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/#findComment-531441 Share on other sites More sharing options...
bob2611 Posted yesterday at 02:44 Author Share Posted yesterday at 02:44 (edited) Thank you for the reply. Admittedly I have not had it serviced. I have power cycled it and I don't seem to get any further. The battery is a like foe like replacement from what was there. It is working as the alarm stays on when I kill the power. If the PSU is shot what is a good like for like replacement where the cabling will be the same so I don't need to replace pirs or bell box Edited yesterday at 02:46 by bob2611 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/#findComment-531442 Share on other sites More sharing options...
sixwheeledbeast Posted 18 hours ago Share Posted 18 hours ago Wants rewiring anyway it's not been wired in the correct cable and there's only 2 zones so I'd start again if I was working on it. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/#findComment-531443 Share on other sites More sharing options...
bob2611 Posted 5 hours ago Author Share Posted 5 hours ago Is this a good replacement option ? https://www.4electrical.co.uk/shop/security/security-alarms/lcd-keypad-security-alarm-8-zones-250-event-memory-2-1ah-battery-200x253x55mm/1066876170 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/#findComment-531444 Share on other sites More sharing options...
al-yeti Posted 4 hours ago Share Posted 4 hours ago On 21/12/2025 at 19:21, bob2611 said: The alarm in my house is just not working. The spanner light is on and I am unable to reset it. The system is about 10 years old. I replace the battery on the unit as I thought that was the issue. No luck. It will let me enter numbers but none of the other buttons will do anything other than give the sound suggestion it's the wrong action. As I said, if I put the master code in, it's not taking it. I would be very grateful if anyone help me understand the issue? Better replace the system , ultimately... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/#findComment-531445 Share on other sites More sharing options...
