Chris A Posted October 13, 2025 Share Posted October 13, 2025 Hi My system has been operating fine since my last post (around 2017) however today a problem has arisen with one of my Honeywell S-215TQ PIRs. I first noticed that the system was going into alarm mode a couple of seconds after setting it. Every time, the same PIR was the cause. I then noticed that this PIR's red light is randomly coming "on" even when there is nothing for it to detect. In fact the light is "on" almost all of the time. It is not lit constantly - it is more of a slow, uneven, flicker. The external lens is clear and there are no new sources nearby that could be interfering with the IR. The PIR is connected to a Scantronic 9651PD using FSL and the whole system is about 12 years old. Is it likely that the PIR needs to be replaced or do the resistors used for FSL fail after a period of time and cause this issue? [The only other thing I think I should add is that yesterday, for the first time in years, I had a "false alarm". But this was down to the fact that one of the protected doors had not been shut properly when the system was set - a case of "user error". Whilst probably not relevant to the issue I have described, I mention just in case it is more than co-incidence?] Any thoughts, as always, will be most welcome. Thanks. Chris. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/ Share on other sites More sharing options...
sixwheeledbeast Posted October 13, 2025 Share Posted October 13, 2025 Check the voltage, connections and cable are good. Consider replacing the sensor. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530975 Share on other sites More sharing options...
al-yeti Posted October 13, 2025 Share Posted October 13, 2025 43 minutes ago, Chris A said: Hi My system has been operating fine since my last post (around 2017) however today a problem has arisen with one of my Honeywell S-215TQ PIRs. I first noticed that the system was going into alarm mode a couple of seconds after setting it. Every time, the same PIR was the cause. I then noticed that this PIR's red light is randomly coming "on" even when there is nothing for it to detect. In fact the light is "on" almost all of the time. It is not lit constantly - it is more of a slow, uneven, flicker. The external lens is clear and there are no new sources nearby that could be interfering with the IR. The PIR is connected to a Scantronic 9651PD using FSL and the whole system is about 12 years old. Is it likely that the PIR needs to be replaced or do the resistors used for FSL fail after a period of time and cause this issue? [The only other thing I think I should add is that yesterday, for the first time in years, I had a "false alarm". But this was down to the fact that one of the protected doors had not been shut properly when the system was set - a case of "user error". Whilst probably not relevant to the issue I have described, I mention just in case it is more than co-incidence?] Any thoughts, as always, will be most welcome. Thanks. Chris. Change the PIR Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530976 Share on other sites More sharing options...
james.wilson Posted October 13, 2025 Share Posted October 13, 2025 2 hours ago, sixwheeledbeast said: Check the voltage, connections and cable are good. Consider replacing the sensor. Qfa securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530977 Share on other sites More sharing options...
Chris A Posted October 14, 2025 Author Share Posted October 14, 2025 First of all, thanks to all three who took the time to respond. Comments very helpful. Strangely, when I got up this morning, the PIR in question had reverted to "normal" operation. I did, however, take the opportunity to check inside. All seemed to be as expected. Whilst there was no trace of anything when I looked, I just wonder if, perhaps, a creepy-crawly had somehow got inside for 24 hours - there is a slight gap where the cable enters. In the event of the problem returning, however, I will just replace it as suggested. Thanks. Chris. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530985 Share on other sites More sharing options...
sixwheeledbeast Posted October 14, 2025 Share Posted October 14, 2025 I would always use sensors with sealed optics to avoid any possibility of this. Optex, Bosch, Texe Capture are some examples. You need to diagnose if it's the system or the environment if you want to work it out. Proper engineers would do this, some would just without diagnosis throw a sensor at it and escape on their horse.... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530986 Share on other sites More sharing options...
PeterJames Posted October 14, 2025 Share Posted October 14, 2025 5 hours ago, Chris A said: I just wonder if, perhaps, a creepy-crawly had somehow got inside for 24 hours - there is a slight gap where the cable enters. My first thought Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530989 Share on other sites More sharing options...
james.wilson Posted October 14, 2025 Share Posted October 14, 2025 The is215 had sealed optics iirc securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530992 Share on other sites More sharing options...
PeterJames Posted October 14, 2025 Share Posted October 14, 2025 3 hours ago, james.wilson said: The is215 had sealed optics iirc Ive seen those tiny midge thingies in sealed optics before Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530997 Share on other sites More sharing options...
al-yeti Posted October 14, 2025 Share Posted October 14, 2025 11 hours ago, Chris A said: First of all, thanks to all three who took the time to respond. Comments very helpful. Strangely, when I got up this morning, the PIR in question had reverted to "normal" operation. I did, however, take the opportunity to check inside. All seemed to be as expected. Whilst there was no trace of anything when I looked, I just wonder if, perhaps, a creepy-crawly had somehow got inside for 24 hours - there is a slight gap where the cable enters. In the event of the problem returning, however, I will just replace it as suggested. Thanks. Chris. I once opened a is215 and cockroach's was trapped inside Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47387-pir-issue/#findComment-530998 Share on other sites More sharing options...
