Bunster Posted April 7 Share Posted April 7 I have a very old intruder alarm which uses an autodialler to contact ADT for monitoring. I am about to be switched to Digital Voice by BT. I understand that I can use an ATA so that the alarm can still contact ADT via Digital Voice. What ATA would be best for this? Thanks! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47190-analogue-telephone-adaptor-recommendations/ Share on other sites More sharing options...
sixwheeledbeast Posted April 7 Share Posted April 7 You could try but there is no guarantee it will work properly. You will also have the issue that a power cut will disable the alarm signalling. Best option is to upgrade the system/signalling to a more modern digital compatible one. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47190-analogue-telephone-adaptor-recommendations/#findComment-528894 Share on other sites More sharing options...
norman Posted April 7 Share Posted April 7 If its still under contract speak to them and let them sort it out. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47190-analogue-telephone-adaptor-recommendations/#findComment-528895 Share on other sites More sharing options...
MrHappy Posted April 7 Share Posted April 7 6 hours ago, Bunster said: What ATA would be best for this? none are likely to work correctly when needed, you either need a digiair as signalling up grade, of replace the controls to one which uses an app Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47190-analogue-telephone-adaptor-recommendations/#findComment-528899 Share on other sites More sharing options...
PeterJames Posted April 7 Share Posted April 7 5 hours ago, norman said: If its still under contract speak to them and let them sort it out. QFA they will charge to sort it out, but like most good companies they will have a solution Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47190-analogue-telephone-adaptor-recommendations/#findComment-528900 Share on other sites More sharing options...
