What wireless panels do people use
9 hours ago, MrHappy said:
The only issue is the mask, used as grade 2 or power cycling once in blue moon will stop false masks which open the alarm relay
Link + to set disables that problem. Lost count of how many calls I’ve had only to find Iwise blinking away.
I think Pyronix TMD’s have mask issues. Strange how the DT false alarms more often than the PIR. I always disable dip switch 6 on a TMD if the system is G2 as I believe it prevents the alarm relay opening on mask.
  • Replies 28
  • Views 6.1k
  • its pretty much bullet proof...     A keyfob which needs powering up, A bizarre manner which to register the connect app An odd little box to go along the controls to connec
  • james.wilson
    james.wilson
    Nothing but hkc here. Wouldn't go anywhere near ajax unless I fitted ring door bells
  • Pyronix for me. The app is main reason. Ive inherited a couple of Ajax systems and they seem solid. At some point I’ll set up a demo system to really check them out. Hard to give the impression y
On 30/03/2022 at 20:21, Jwiggand said:
Never used those panels. Would you recommend those ones then. Don’t actually do too much wireless ,and when we have had to in commercial places it’s normally expanding a ion with wireless expanders.
Ion is one of the worst without a doubt , probably someone chose it because they have on in there house instead of looking at the commercial qualities of other panels against the ion
On 30/03/2022 at 21:14, james.wilson said:
Isnt Ion 1 way wireless?
Yup. And it has a horrendous sleep time. Not sure on the specifics but it feels like forever.
Its for a local council and every building is a ion ,older scannie or menvier. We are quite restricted with what we can use. All dvr/nvr have to be Bosch
Thats just 1 issue with 1 way, im amazed its still used /available in pro product, i get it with diy stuff though
What Bosch they use
Some of these decision makers in councils take far to long to retire , dictators lol
On 01/04/2022 at 11:56, al-yeti said:
What Bosch they use
They use the Bosch divar stuff. I’m not really a fan. It’s super basic kit which is good because some of the dopes who work at the same company can fumble their way through setting them up and using them but it’s interface seems quite old fashioned.
They took advice from the the guy who manages the boroughs central cctv room for road and street cameras, and the dvrs they chose couldn’t even take a 4mp camera ?
I see why people specify stuff, Bosch not so much but its still specified, Its a brand name and doesnt matter how other stuff performs cos ive heard of x y. Ive worked with it and feel it looses out to most other main stream stuff. You should show them them difference
They know Bosch will always be NDAA. Even tho it's an American ruling it's considered more and more in public sector.
