Ring Cameras
35 minutes ago, scrimshanker said:
If you're in to stopping the break in then surely you're all about steel doors, smoke cloaks and window bars, because alarms and cctv don't stop break ins they just make you aware it's happened and allow you to investigate post break in
I never said it wasn't consumer, just asked whether it had a role.
How does CCTV make you aware at the time it's happening , your going rely on push notifications lol
Come on be more serious
  • Replies 99
  • Views 19.2k
  • sixwheeledbeast
    sixwheeledbeast
    I don't like this attitude, condescending to rule out everybody else's opinion as childish because it doesn't align with your opinions. Maybe your not but it comes across that way. Remember most
  • Just asking? More than just asking dude ......   You mean like special brew ? Your favourite?
  • sixwheeledbeast
    sixwheeledbeast
    Professional Lol. Modern Micromark.
I said it helps with the investigation post break in! Meaning after the break in, it doesn't help with being alerted it's happening.
You arent the only pro here, I was asking for your thoughts on whether ring cameras could substitute full cctv for domestics which don't need full cctv
its 2020 petrol & battery powered cutting stuff is going to open up most premises despite there psychical security
the nice thing about about alarm is the EWD, twated off the wall at the start of the break starts the 1st signal, unlike cctv it gonna work in power cut & probably gonna signal even when the internet or telephone line get cut.
& its probably in place due to the insurer rather than the subscriber wanting it & the rozzers might even turn up on confirmed alarm
the people with shutters, safes & alarm rarely get robbed
the people with sawn cctv, yale alarm apps ect.. do get robbed
I am not a pro
Ring cameras are not real CCTV , they are door bells and floodlights with a camera on them
Substitute is just cos they cheap and aimed at DIY market
You plan to start it as a ring installer hence you fit a door bell get your £60 and your done , I assume this is really y your asking
12 minutes ago, al-yeti said:
I am not a pro
Not in the slightest, haven't got time. Too busy working on national infrastructure project and public space.
I was simply curious and that's all. I understand the it will be knocked off the wall etc but that's not the real reason for something like this, it's more for everyday awareness outside your home. Not security.
Oh, and thanks for all the negative ratings for asking a question on here and getting involved.
That's what I like about this forum, it's open, friendly, helpful and not at all a bullying environment you are judged in.
That's great , thick skinned , but the red badges look good on you
Few years you could sell them at auction
Personally I only give positive rating -
cause I get bored hearing the whining that from negative ratings
TSI is mostly a bunch of embittered tradesmen ripping the pish of each other
its also quite mild to what it once was ?
