Problem with Texecom Smartcom
Hi
I recently purchased a Texecom 64-W wireless kit Version 5 and a Smartcom module for APP connection. The problem I am having is that when I try to generate an APP code by "Enable Texecom Connect APP" for an APP passcode to be generated, it eventually comes back with "NO CARRIER" meaning no access to the Cloud.  I have Virgin media business broadband at home as it's where  I run my business from and according to Texecom tech support, Websafe has to be disabled to allow access for the Smartcom to the Cloud. I was told to get the client to log into their Virgin Media account online and to disable Websafe.
Has anybody come across this before connecting via Virgin Media.
PLEASE HELP!!!
  • Replies 35
  • Views 32.4k
  • Created
  • Last Reply
Top Posters In This Topic
Only way is to try it
https://www.virginmedia.com/help/how-to-use-websafe
Also possible you could change the DNS setting on the smart com if it let's you to 8.8.8.8 the usual lol and see if that helps , I didn't know your panel well so not sure what settings are available
To prove router etc coukd you use your own phones Access point temp to prove the gear etc
Never had this issue but I would imagine there is some allow list somewhere that you can add *.texe.com to if you didn't want to disable their Websafe.
Although ISP provided routers are generally junk so maybe not.
Thanks guys for your replies
Why can't it just be straight forward like Visonic and Pyronix for crying out loud.  WHAT IS IT ABOUT TEXECOM
Because reality even though it's "meh" texecon isn't DIY friendly
best selling, i quite different from best product
they also tinker for the sake of tinkering & make stuff worse
agreed texecom, pyronix is where the numbers are at
