G2 44+ PSU fault
  • Replies 31
  • Views 7.5k
  • have you considered buying a dog ?
  • Reassuring to know it's not just me James! Swapped out just the power supply bit after removing the ribbon cables. It was fully compatible with the existing RIO main board and problem solved immediate
  • 10 months later...
Forgot about this. In the end the bloody thing just started behaving itself, guess the multimeter gave it a scare
I've been waiting with baited breath for the results....
  • 11 months later...
Just because I know Mr Happy was waiting for this, it's started doing it again intermittently: AC FAIL PSU 103.
Opened the powered RIO panel, couldn't see a problem, tested mains side (good) and got 13V odd on the other side. The ribbon connector on the RIO side was slightly loose so pressed that home (moved maybe a millimeter).
Anyone have any more news about this fault on the newer boards?
I still do not have a dog.
Edited by Driller
you checked the flux capacitor ?
There's a flux capacitor?! ?
