Eaton Ion-40H Alarm Error - Setting Faults - Front Door Exit
27 minutes ago, NLondonLem said:
I've been struggling to reach my engineer recently
He probably didn't charge you enough
  • Replies 26
  • Views 14.3k
  • james.wilson
    james.wilson
    not on some they need the door closed at exit start
he is
Folks, would appreciate constructive rather than flaming/tongue in cheek comments please. My installer charged a fair price and is very friendly & knowledgeable. I came on here looking for a second opinion in case something may have been overlooked and perhaps given the experience in these forums someone had seen something similar that they had resolved. Cheers
well you may be disappointed.... I like to think we the old fashioned bear pit sort of forum ?
either it ain't programmed right or you ain't using right
close all the internal doors, enter the code with front door shunt & leave promptly ;)
I have had similar issues with final door AND wireless contact, when door is already open AND final set. I have never seen a bulletin for any sort of firmware issue as such, though.
Latest software is 6.01, beware though, this update finally allows installer to lock panel. However if you can see programming I assume installer has given you engineer code??
Edited by datadiffusion
So get another installer because seems you willing to pay and want important security , which clearly you won't be able to fix
And it's forum banter you can't escape from
1 minute ago, Logan said:
See you got Asian software aswell
