Scantronic 4600 door contacts not functioning
  • Replies 80
  • Views 17.5k
  • james.wilson
    james.wilson
    helmand province?
  • PeterJames
    PeterJames
    We are in Storrington West sussex but we are not the cheapest company, (we are not the most expensive either) it depends on what you want  but we only supply quality kit which we install professionall
  • PeterJames
    PeterJames
    You can solder new batteries on these Ive done it in the past
10 minutes ago, Johnc said:
Sure I shall take some photos tomorrow. Thank you for your help
 cool
To the company in Storrington, if you can let me know the name or contact details I shall contact you once restrictions are lifted. Many thanks
How to setup two links on the 4600 terminals, do you mean on the faulty unit or the 4600 main control box. Not sure what the process would be to setup two links
we are trying to confirm that the unit has failed. If you put a wire link between each set of the terminals to ensure its not external. Im thinking as the built in reed isnt working your fault is here or external.
Remove the black and blue and place a wire link where they were and do the same for red and yellow and report back.
You will also need to hold down the tamper switches and reset the panel or put it back in the casing and place the lid back on correclty.
Hi John
Ill email you
