Abacus fault
Hi I have an old Abacus system.It was working perfectly. Then I had my front door changed and the alarm light doesn't work on the house.
Anybody familiar with the wiring for the Abacus 12 system or think they can help. I have the original installation manual and installation wiring setup.
The company telephone numbers I have for support no longer work.
I'm SE London Brockley/Peckham. Please let me know if you think you can help.
Which alarm light?
iD system so if the old contact and biscuit have gone, you'll struggle to get it working. All the parts are obsolete and hard or expensive to find.
really ?
fire up your ford orion & go & knock on their door...
On 18/03/2020 at 11:36, james.wilson said:
Which alarm light?
The light/bell on the outside of the house.
On 18/03/2020 at 12:15, MrHappy said:
really ?
Toyota Corona would be better now tho, man be serious
If everything else is working I can't see how they are related. There usually isn't any power going to a contact. When was it last serviced etc?
