2 hours ago, al-yeti said:
I didn't find many with worn out buttons just other faults
Yeah after you put them there you conman
  • Thanks 1
On 03/03/2020 at 22:56, EECARE said:
Hi every one and a big hello to you all.
, I am an approved electrician and am based in Wembley Middlesex
i am starting to e we irk on security system recently and need a good forum ho gain my knowledge and share my work on,  this is the first forum I came across and decided to give it a go.
now first question for the day,
need to replace a faulty alarm keypad,
first which one would be ideal direct replacement, there is no make of manufacture or model number on the alarm main panel or keypad
So please someone help!!!
see image below in the link
https://www.dropbox.com/s/5npdfsrif3stf1q/60496040246__D8956933-B4CB-430E-9F11-9B9BC60013EF.JPG?dl=0
This is the main alarm panel, does anyone know what company this alarm panel is?
The posts above cover everything.
It's a TS series Menvier. Could be either a 590 690 700 790, either way...
On 04/03/2020 at 17:32, sixwheeledbeast said:
You can take all the pictures you want but you will not find a replacement at the wholesalers everything TS series is obsolete.
I agree with above who says it's faulty? Possible XY problem?
On 03/03/2020 at 23:02, MrHappy said:
Option A
fire up the deloran, selected 2000ish & pop into your local branch of CSD professional
Option B-
New old stock from fleabay (lol)
Option C-
Rip it out & stamp on it & put some new controls in
If you are struggling now with the water around your ankles, you'll be drowning if you take the lid off and start poking around.
Time to admit defeat and pass this job on to a professional, I'd say.
Register a new account
Sign in
