Help understanding EOL wiring.
1 minute ago, Logan said:
Yes
I just couldn't get it from OP's diagram. Seems to be making things more confusing than need be.
  • Replies 40
  • Views 17.6k
  • No, I'm in the English, we don't do that sort of thing...     In his part of the world they probably, have dead dogs in the street, open sewers & wire alarm funny....
  • Forget this drawing , as jw already said what you done is ok
  • sixwheeledbeast
    sixwheeledbeast
    Better passives with resistors built in is an option too.
4 hours ago, Steve23 said:
resistors 1k & 3k ?
tamper & alarm relay closed, circuit reads 4k
alarm relay opens, circuit goes 100k> & alarm goes into tamper...
But remember we are alarm engineers and that is basic diagrams to us.
If you say so
1 hour ago, SecureAlarms said:
1k across the A + A. 1K across A + T. 1 Core in 1st A. Second Core in Unused T.
Thanks I'm starting the understand things now.
I like your explanation it's so simple even I understand it.
Yeah that diagram was what I got sent by someone which confused me as it contradicted everything I'd been reading.
Don't worry I am still confused to this day , but hanging around here keeps my mind boggled proper and helps plenty
20 hours ago, Steve23 said:
Although the manual does recommend Cat5 cable.
Are you sure? I'd be amazed.
It may mention screened cable for keypads and nodes, but this is still flexible type.
Ah yeah I think I read it wrong its in the Peripheral devices section.
Ah that's a new one, I'm not big on Galaxy/Honeywell, but IIRC they used to recommend screened Belden cable, again only for long-run peripherals.
In fact, using any solid core wiring FOR ALARMS (OBVIOUSLY) is a really bad idea IMHO, from an installer 'boots on the ground' PoV.
Edited by datadiffusion
I agree with above all too easy for the stuff to snap and create faults especially if it's been in a while.
