Replace outside alarm battery Odyssey 1E - Texecom
1 hour ago, MrHappy said:
My person fav was end stations needing a triple ladder for access !
Good while ago but I recall a job where install lad purposely fitted panel TS700 IIRC at high level in the warehouse because the service lad that was from that area was a lazy feck...
  • Replies 32
  • Views 11.4k
  • You'd never be brave enough to go to Wakefield it's that rough even the muggers have to go out in pairs....
  • sixwheeledbeast
    sixwheeledbeast
    Maybe, that wasn't the question tho.
  • datadiffusion
    datadiffusion
    What really pisses me off is when they put bells above ground floor bay window roof, especially when they had the pick of the whole front and it would have looked BETTER elsewhere
4 minutes ago, Logan said:
I want that integra lol
A while back I saved & sent one out for one of the other lads on here that collects.
6 minutes ago, Logan said:
You mean MrData Diffusion nerd
no, another young lad
DD will be removing tat however by the time it comes off the wall its had 20yrs of sunshine, rain & birdshit on the plastics...
Yep it's sadly rare to remove anything that I don't feel belongs in the bin with a few kicks for good measure... Even inside stuff is usually yellowed or covered in paint :(
Or sometimes not even that old in the first place and so not that collectible.
In fact I think it's fair to say I see the most interesting older alarm stuff when I'm on the ambo!
Edited by datadiffusion
Junk
This particular box cover was in pristine condition, after the owner cleaned out the cobwebs and washed it.
Interestingly, a single housefly flew out when first opened; it must have been attracted by the heat, doesn't say much for the IP rating though.
Jaymack
IIRC the IP rating refers to the electronics ?
the E (Economy version) didn't have has rubber gasket seal on the internal plastic cover
