January 14, 20206 yr comment_493682 How to replace the battery for a Texecom, Odyssey 1E?, the existing one seems to be held in place - but how? Jaymack Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 14, 20206 yr comment_493683 It's a NiMH pack inside the "high voltage" strobe case, which has large plastic tabs to open. Some are stuck with pads to the PCB, others are cable tied. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493683 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 14, 20206 yr comment_493685 Maybe, that wasn't the question tho. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493685 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 14, 20206 yr comment_493686 2 hours ago, John McLean said: How to replace the battery for a Texecom, Odyssey 1E?, the existing one seems to be held in place - but how? Jaymack Replace cover while your at it if it doesn't clean up well , but as swb says , battery cheap to replace Chop that bad boy out and put a new battery in if your capable Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493686 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 14, 20206 yr comment_493687 OP - Prying the case apart at height is pain, getting it to close again is pain... Have fun. Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493687 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 15, 20206 yr comment_493730 Personally I would replace the unit, it will then be warrantied and save a lot of messing in the long run Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493730 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 15, 20206 yr Author comment_493733 Thanks for the help, it's difficult to see how the battery is fixed to the casing, when standing on a ladder 5 metres above the ground - 1 hand for me and the other for working. I'll use a screwdriver to prise it off since it appears to be simply stuck on and no help notice. What is worse, that not being left handed, the right hand is for holding on and the useless mitt is the left hand for working on. Why there is no space at the left hand side for ladder access ,is probably because it was installed by a left handed installer. I now have replacements for both 9 year old batteries. These alarm boxes needn't be mounted so high, I think that 3m is high enough. Jaymack Edited January 15, 20206 yr by John McLean Grammar Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493733 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 15, 20206 yr comment_493734 I sympathise with you, I think we have all probably had a awkward bell box at some stage to contend with Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493734 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 15, 20206 yr comment_493737 When a sounder is unsafe to access it's worth considering decommissioning/re-siting/replacing Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493737 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
January 15, 20206 yr comment_493744 3 hours ago, John McLean said: Thanks for the help, it's difficult to see how the battery is fixed to the casing, when standing on a ladder 5 metres above the ground - 1 hand for me and the other for working. I'll use a screwdriver to prise it off since it appears to be simply stuck on and no help notice. What is worse, that not being left handed, the right hand is for holding on and the useless mitt is the left hand for working on. Why there is no space at the left hand side for ladder access ,is probably because it was installed by a left handed installer. I now have replacements for both 9 year old batteries. These alarm boxes needn't be mounted so high, I think that 3m is high enough. Jaymack Yes there are some right Muppets when installing bells Then customers become Muppets aswell when they want it high like the Muppet neighbours External bell boxes mostly ignored when they gain access from rear and no internal sounder fitted ...... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43446-replace-outside-alarm-battery-odyssey-1e-texecom/#findComment-493744 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
