Replace outside alarm battery Odyssey 1E - Texecom
How to replace the battery for a Texecom, Odyssey 1E?, the existing one seems to be held in place - but how?
Jaymack
  • Replies 32
  • Views 12.3k
  • You'd never be brave enough to go to Wakefield it's that rough even the muggers have to go out in pairs....
  • sixwheeledbeast
    sixwheeledbeast
    Maybe, that wasn't the question tho.
  • datadiffusion
    datadiffusion
    What really pisses me off is when they put bells above ground floor bay window roof, especially when they had the pick of the whole front and it would have looked BETTER elsewhere
It's a NiMH pack inside the "high voltage" strobe case, which has large plastic tabs to open.
Some are stuck with pads to the PCB, others are cable tied.
Jaymack
Replace cover while your at it if it doesn't clean up well , but as swb says , battery cheap to replace
Chop that bad boy out and put a new battery in if your capable
OP - Prying the case apart at height is pain, getting it to close again is pain...
Have fun.
Personally I would replace the unit, it will then be warrantied and save a lot of messing in the long run
Thanks for the help, it's difficult to see how the battery is fixed to the casing, when standing on a ladder 5 metres above the ground - 1 hand for me and the other for working. I'll use a screwdriver to prise it off since it appears to be simply stuck on and no help notice. What is worse, that not being left handed, the right hand is for holding on and the useless mitt is the left hand for working on. Why there is no space at the left hand side for ladder access ,is probably because it was installed by a left handed installer. :realmad: I now have replacements for both 9 year old batteries. These alarm boxes needn't be mounted so high, I think that 3m is high enough.
Jaymack
Edited by John McLean
Grammar
I sympathise with you, I think we have all probably had a awkward bell box at some stage to contend with
Jaymack
Yes there are some right Muppets when installing bells
Then customers become Muppets aswell when they want it high like the Muppet neighbours
External bell boxes mostly ignored when they gain access from rear and no internal sounder fitted ......
