Galaxy G2-20 problem
Hi all
I have a G2-20 panel which is randomly setting off, when I look on the log it has the detector which triggered the false alarm then it will always have Batt Mis proceeding the alarm.
I have checked the battery but it still does it, is this a faulty panel and if so what is the new equivalent of a G2-20 as I have read that they are now obsolete?
Cheers
G2 is still available
But I'd check everything before condemning it
I don't fit Galaxy but would be surprised if they dropped the 2-20.
Control panels are very rarely faulty from experience, you need to rule out external factors as throwing a panel at it is relatively expensive and will piss the customer off if it's something else.
There could be something shorting to ground and dragging the system down, or maybe even the battery is faulty but appears ok if you test it. Not an exhaustive list of what it could be tho.
Dodgy battery spade connector?
28 minutes ago, d-tec services said:
Hi all
Cheers
How old is system panel battery? I would change that first
Standard on these to show bat mis when they dodge , only ever got one panel with that fault similar and was panel
Change battery
I had a 12 ah battery installed, changed it now to a 7 ah, does it cause the PSU to work harder to charge up a bigger battery?
Yes especially if your pushing more day mode current
  • 1 month later...
Only on a complete discharge or new battery senario the rest of the time it's on trickle charge which hardly takes anything.
Regards TS
