What texecom system to get?
When you purchase an alarm system from a company you are essentially buying a service not a product.
The companies will support specific control panels for many reasons, they maybe knowledgable and trained with that manufacturer, have stock available at short notice the panel generally fits the companies operations in well established places.
Asking someone to install a system they can't support or have no knowledge of is a bad idea, you will likely get a poorly installed system with at least teething problems.
You honestly need to decide which route to take, are you DIYing or are you having it installed. If the latter then of your quotes go with the company you feel most comfortable with, forget about the brand (just make sure it's 2 way if wireless).
  • 1 month later...
  • Replies 35
  • Views 12.2k
  • There you go again grade 3 must be better its a bigger number and it costs more. Seriously you dont want G3, I can count on one hand how many G3 domestic systems we have out there, nearly all our G3 s
  • Peter,    Thanks very much for the advice - I'll take that on board. What would you suggest for a reliable wireless system (but with the option to hard wire stuff, like distant sensors, cont
Engineer code /master code can easily be defaulted anyway with out defaulting the whole panel so it’s not a big issue even if they don’t give you the engineer code
Assuming that its not locked, but I agree with six wheel anyone blindly taking over a system willy nilly with his fingers crossed hoping the incumbent co programmed it right is not only unprofessional, but sooner or later will end up becoming a victim of his own laziness.
And stinginess
