IP redirect ?
I've an old piece of hardware which needs a firmware update
however its servers have changed, but I can't change the setting in the device
However I suspect I might be able to change settings in the router...
so when it "dials" 11.11.11.11 it redirected to 22.22.22.22
google isn't helping, but I not quite sure of the proper term for what I'm trying to do
Router is draytek 2820.
Thanks in advance :)
you need a dns server
i think you mean ddns?
you can probably redirect on the router id its a domain. Dunno how to do it if its an ip
Siemens phone by any chance ?
www.nova-security.co.uk
www.nsiapproved.co.uk
nope
Sounds like potentially more hassle than it's worth, but I have no idea what you are trying to do so maybe an "XY problem"?
Connect it to the net via a proxy that you have setup to point at the right place?
Hosts file or DNS server solutions could be possible if you are doing a DNS lookup, sounds like it isn't as you have IP's?
Could you get hold of the firmware ?
If you could then use filezilla
