October 2, 20188 yr comment_479644 Newbie on here - am not an engineer, but have some experience in wiring, have installed a few systems successfully, though straightforward and simple ones. Jut fitted a new Optima compact gen4 (LED and no external keypad) and as expected - in alarm state as soon as its powered up, so logic(?) i enter the default code - no change, try the engineers code - nothing - I am stuck with it. no faults showing, not even tamper on cover, but just the red power LCD, as though armed/set I believe. Have done both reset to factory settings and reset user codes procedures (link from SET to PA or TAMP respectively) - no change there. set up 'as it arrived' apart from my 3 zones connected, maybe I've got a link in that shouldn't be or vice versa? grateful for any ideas anyone? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr comment_479645 is anything connected to it? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479645 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr comment_479646 Factory default and power up with nothing connected to prove the panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479646 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr Author comment_479647 connected yes - as this, tried with nothing too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479647 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr comment_479648 2 hours ago, Jack2000 said: Newbie on here - am not an engineer, but have some experience in wiring, have installed a few systems successfully, though straightforward and simple ones. Jut fitted a new Optima compact gen4 (LED and no external keypad) and as expected - in alarm state as soon as its powered up, so logic(?) i enter the default code - no change, try the engineers code - nothing - I am stuck with it. no faults showing, not even tamper on cover, but just the red power LCD, as though armed/set I believe. Have done both reset to factory settings and reset user codes procedures (link from SET to PA or TAMP respectively) - no change there. set up 'as it arrived' apart from my 3 zones connected, maybe I've got a link in that shouldn't be or vice versa? grateful for any ideas anyone? Do the keys respond in anyway when you press them Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479648 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr comment_479649 Is the factory fitted link in place? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479649 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr Author comment_479650 to Al- yeti - no - except for a slight 'beep' when the 3 of the default 0123 code is pressed. Mr happy - Ah - not sure - so on the as delivered panel (per diagram) - PA - TAMP and SCB are still there - plus TAMP on the left hand site connectors Edited October 2, 20188 yr by Jack2000 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479650 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr comment_479651 42 minutes ago, Jack2000 said: to Al- yeti - no - except for a slight 'beep' when the 3 of the default 0123 code is pressed. Mr happy - Ah - not sure - so on the as delivered panel (per diagram) - PA - TAMP and SCB are still there - plus TAMP on the left hand site connectors Can you take a picture with the top cover off? 1 minute ago, al-yeti said: Can you take a picture with the top cover off? Maybe that you have damage the ribbon cable or its not in properly , power down and insert correctly and try again Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479651 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr Author comment_479652 no need for a picture Al-yeti, you are indeed a star - it was the ribbon cable - pushed the connector home and bingo. Can't thank you enough, get down the boozer - I'll buy you a pint. what a bleeding relief! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479652 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 2, 20188 yr comment_479653 1 hour ago, Jack2000 said: no need for a picture Al-yeti, you are indeed a star - it was the ribbon cable - pushed the connector home and bingo. Can't thank you enough, get down the boozer - I'll buy you a pint. what a bleeding relief! I learnt that here at TSI Thanks to alarm monkies Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42423-optima-compact-gen4/#findComment-479653 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
