Gardtec 800 part set procedure
All down to if it's wired DP or EOL. More systems are wired EOL, inverting the wires shouldn't make a difference so maybe something is loose/shorting out.
Selectable you will have to make sure they are compatible with your panel normally you cut a link within them, or you can get ones with screw terminals which you can fit your resistors in.
  • Replies 29
  • Views 8.1k
  • swapping the colours around make no difference to the circuit,   your picture shows the strands of the cable touching.... that is probably why it was in tamper
  • Hillbilly
    Hillbilly
    System will be fine powered up to change the contact.
  • Hillbilly
    Hillbilly
    You can replace with any panel but the 600 has the same setting procedure as the old gardtec. It also has a built in dialler.  With the bell up here its all pyronix backlight.
Thankyou
the picture here is the way I wire it up first but had a continuous tamper ....
then swopped the yellow and black, as per a DIY site...and it worked !!!
On 14/05/2018 at 17:41, Calibra said:
Hello
i had the black and yellow wire swopped.....
now tamper has cleaed and all,ok...
would still like to know about the selectable resistor contacts ?
thanks for all the help
Wires being swapped shouldn't have caused an issue though
Lol missed your post somehow , although I didn't look for strands which was going to be my next comment
Still training .........
The strands along with the core of the yellow wire need to go correctly under the screw also, basic stuff needs a bit of practice.
It also looks as though you have nicked the yellow insulation.
Hello
yes was fiddly, but works perfectly now it’s tidied up, another skill learnt LOL
Practice makes perfect - in some cases, joke,  :genius:
magpye
