Texecom Premier Elite - Cut Cable :(
Morning gents! :D
Based on a lot of background reading I did on this forum, a Texecom Premier Elite was fitted about 6 months ago and a great alarm it is too! :)
Problem I have now is that when cutting off some cornice at the top of the ceiling, we completely forgot that the telephone and alarm cable was run through there. As such, we cut through the damn thing. :( I'd like to patch this up as it leads to a key patio door sensor.
The bigger issue is that the cable is crappy CCA (copper clad alu) as opposed to quality cable. Don't ask how or why that was used. :(
So I guess question is how do I connect this crappy cable back up again? Can't solder it.
I can only think of something like this (a pack of ten is a couple quid and they are tiny):
https://www.tlc-direct.co.uk/Products/WA415.html
Also, as the system is 'live' and I don't wish to short anything, how would I power it down temporarily?
  • Replies 31
  • Views 7.3k
  • Due to location and space I would go with solder and any type of wrapping , not gift wrap though
  • A regular soldering iron will be fine, if you are unsure have a practice first on some old spare cable.   Lots of tutorials on YT.
  • sixwheeledbeast
    sixwheeledbeast
    60/40 electronics solder or most stock the lead free equivalent, flux is in the solder core (rosin). Do not use plumbing solder it's not suitable.
Just to clear up on the above, my choices (unless you guys have a better suggestion) at the moment to fix this mess are:
(1)Lever splicing connector:
(2) Some crimps:
https://www.tlc-direct.co.uk/Main_Index/Cable_Accessories_Index/Crimp_Lugs_and_Tools/index.html
(3) A small, 2a connector strip (two-way):
https://www.tlc-direct.co.uk/Products/TLCON2.html
Edited by MarkJohnson
Thanks for the replies folks. With regards to solder, I don't think it would work, primarily because it's basically aluminium cable (CCA) and also it is 2.4m up, so a bit awkward to solder on a ladder. But the CCA issue here is the real problem, otherwise I'd have soldered the damn thing already. :(
Use the cable as a fish and rewire would be my first consideration.
CCA will solder with the right temperature and solder.
You making this all up?
Id solder and heat shrink. Melting temp of ali is quite high compared to a soldering iron. Its not copper pipe you dont need a blow torch
Never stopped JBE
doubt a lighter would melt it before it soldered
