Work extension and tech upgrade
Hi Everyone,
Hope all is well in the installer world.   A few of you may remember my installation of CCTV and Galaxy panels of a few years ago (and much mirth over drainpipes ;)).
I'm going to be building a large extension on the work premises and although the current G2-44 with it's extra RIO panel should hold it's own, the analogue Techwin CCTV is going to need an upgrade to a 16 channel IP system.  Will probably upgrade the home system at the same time, this time with a bit more Symmetry perhaps...
It seems that a lot has changed in the time since the last install with IP being the go-to thing.  It would appear that in middle of the road systems there is a choice between 2MP with 4MP being even better if there is sufficient bandwidth in the network to support it.  Same principles for FOV and choosing lenses presumably.
Having got my head quite well around the analogue world I now find myself a newby in the world of IP.  Any general tips or recommendations? Will probably go for Techwin again for good quality to price ratio although they appear to have been bought out by another company.
In addition can anyone recommend a standalone duplex IP intercom system that could be used between say 10 rooms with each unit being able to call all the others, not necessarily with a door unit (this could be a separate system)?
  • Replies 93
  • Views 18.2k
  • he'll have the linksys type
  • sixwheeledbeast
    sixwheeledbeast
    Honda and Rossi will always have opposite agendas since they parted.  2015 was an interesting season several debatable events right through the season, the back of the grid penalty at the last ra
  • Reminds me of the old sketch done by Harry Enfield, with the two geezers down the pub talking about Nigel Mansell speeding
Well, all the local medical establishments use either aiphone or Bosch for intercom, used to use Philips M100 but it appears thats long gone!
(I've just reread and see you were after voip anyway). I have setup an intercom using freepbx on a raspberry pi and cheap snom handsets. That way you can use the presets to dial a 'voice page' etc... which if answered becomes a speakerphone call.
Edited by datadiffusion
34 minutes ago, Driller said:
Hi Everyone,
Seems you will be buying hiwatch made by hikvision plenty options available it seems , goto be better than swann.....
I'm using Axis budget brand Chincåm
51 minutes ago, Driller said:
Hi Everyone,
I trust your fall pipes are as shiny as the day you fitted 'em
Hi Mr H, how are you? It's been a while.  Actually they need a bit of a polish, are you offering? :-D
That's an interesting idea.  We have an IP phone system in place with Cisco units so maybe that could be modified.  Need to be a one touch affair though.
Was hoping to avoid Hikvision, Swann no chance lol
24 minutes ago, datadiffusion said:
Axis ya tightwad!
Looks like their prices have dropped drastically, could be a possibility.  Any thoughts on 2mp vs 4mp?
Love the new multi quote system btw!
Edited by Driller
I know very little about Cisco as they are a bit proprietary for my liking, but on the snom I simply programmed each of the 12 fastdial keys with the voice page code followed by the extension, cloned the quickdials across all the units, and printed inlays as required.
I imagine the Cisco would offer pretty much exactly the same features though?
Been a while since I have seen your name around, all well in the drilling dept?
Would a HD coax or hybrid solution be an option if you want to keep the existing without re-cabling?
You will need to think about your infrastructure and bandwidth if using IP, it all depends on the site.
That sounds like it could work well and I just just found the web based setup for the Ciscos so will give it a bash-thanks!
Hi SWB, yeah the drilling's going good thanks, must be doing something right as they're dying to get in lol
TBH I think the easiest is going to be a rewire-it's all single storey with suspended ceilings so dead easy for pulling network cables and that way I get to sample the joy of IP.  For bandwidth presumably good quality CAT6 or 7 with a clean install and decent POE switch?
You still following F1? Rosberg finally got it (controversially) but it's all got a bit tedious now.
