Magnetic Contacts Sticking on Un-Opened Windows
34 minutes ago, Eugene's DIY Den said:
After over a year and a half since I posted this, several more contacts have stuck (on windows that are never opened).
I would say common on those standard contacts
  • Replies 44
  • Views 9.3k
  • The reed is just little bit of metal in glass tube....   I reckon most of the branded alarm contact manufactures buy in the same Reeds...   The gases escapes for the glass tube &am
  • I think these contacts have done you proud. Time to replace them.
  • there on surfaces which are stepped apart, a "chunky contact" does 30-40mm gap I wouldn't fit then in the locations you've got
Anyway I'm adding a few PIR's to act as backup (and implementing an exercise schedule for the windows :rolleyes:).
Everything should be tested once a month on the user walk test anyway?
User test every 10years or never
  • 4 weeks later...
Why do you need 22 contacts anyway? You only need to put them on external entries/exits, let the PIR's do their job.
Alistair
Alistair
Depends on how many opener's he has
Pirs won't do perimeter protection but save money tho
Insurers like every external door contacted
Funny that many entries are the kitchen windows , or the panel in the door
Contacts have limited use for detecting a break in, they are mandatory for making sure the numpties shut all the doors.
As 6wb to lower risk to prevent doors being left open as well as detection
