I could do with some help
I had an alarm system installed in 2002 and never really used it.
Anyway the fire alarm keeps going off and we dont have a fire.
I have added the pictures, not sure if you can tell me the model or any help.
if I do pin then 6 it changes the time, 0 does call cs, 5 does pin change.
if you could help me that would be great, the company that fitted it are closed.
Phil
  • Replies 24
  • Views 5.6k
  • Give them a call and explain that, let us know how you get on.
  • I would not need any codes to work on your existing system     What a set of bastards... imagine your next disappointment when you discoverer the smoke detectors not been manufactured
  • Just link it out, no come back from dead people...
Phil
What you mean fire alarm keeps going off
You got a picture of when it's in fault?
Fire Z06 Alarm then Zone 06 it says,
Basically, it started at 3am last night and just went off.. the internal alarm was sounding but the outside box does not.
It started again about 4pm and then again.. so I want to try and disable Zone 06
Edited by PhilUK
I also tried 7890 and that wont take me into installer mode as it could be that system.
I also got K01 Excess Keys
when I was messing about.. I think I went a bit crazy!
Edited by PhilUK
You wont get in with 7890 the engineer code would have been changed. Have you tried calling your installer?  If its not been serviced since 2002 its likely your problem will be battery related, it should have been replaced four times since 2002
The alarming company are going strong id give em a call. Sounds like a tamper on cct6
As for the model it will almost certainly be a Scantronic 9651EN, as it has no 'banner text' meaning it's not going to be a 9651UK (which shows only 9651 in the 2nd line) or any other 9x5x, unless the banner text was left blank which is unlikely.
Fire zones is showing rather than tamper faults so this is a little odd. Is the panel in what used to be an unfinished garage? Just wondering if there is a boxed in sensor in the former open roofspace??
But as above TAC are very much a going concern, and quite good from what I've heard. It will need a new system battery as well as a fix.
Edited by datadiffusion
The tamper thing was my fault.. its nothing to with the error. I was just showing it to locate what system I have.
The system started to go off last night, the error was Fire Z06 Alarm then Zone 06 however I just went down and entered my code and it reset it.
I didnt think much more off it.. until it started to do it again today. I left it in error mode hoping that would stop it.. however it didnt.
The error is part of zone 6 which is the smoke alarm part. I want to disable that but without the right code (07890) or 7890 does not work.
I contacted the company out of hours to find out the code.
To answer the above, it was once in the garage which was converted to a room in 2007 and been fine since. I think there is a fault with the smoke sensor.
We are selling the house, so just wanted to disable zone 6 as I dont really use the alarm.
Edited by PhilUK
No they won't tell you it, but they will come out and default it for you (for a cost obviously), much cheaper than a sleepless night...
