Outdoor Sensors - 1B-100 PERIMETER ALARM
Hi, I am looking for an outdoor perimeter alarm system.
I have only just started my research so my knowledge is limited.
How reliable are outdoor sensors?
https://www.ultrasecuredirect.com/wireless-outdoor-alarms/solar-powered-wireless-perimeter-alarm/long-range-wireless-perimeter-alarm-900-metre-004-2590-p219.html
I found these above, based on the description they sound like that would be suitable, they work in pairs so both have to be triggered to raise the alarm.
Regards
John
  • Replies 43
  • Views 8.2k
  • the solar tat is upto 1km in range, (radio, not the the beam pair)   the visonic tat is a pir for back garden, the sort of size with neighbours with cats, balls ect....   I suspect
  • optex beams & sensors...   I don't like outside detection,
  • PeterJames
    PeterJames
    Who were you expecting to call? I get the logic, but in order to be able to give advice,it would be sensible to understand the risk.  Are you expecting to be targeted specifically? Could it just
Chinky tat,
but work quite well, brackets ain't great, programming is worse, unlikely to work all the time off solar in the UK as not enough charge to go over night
its a chime for the drive rather than security...
14 minutes ago, MrHappy said:
EXPENSIVE Chinky tat,
Fixed.
P.S OP you also posted the same question to a 3 year old topic (that had degenerated into an argument between members) - I've deleted this, you've done the right thing starting a new one like this, please don't double post or bump old topics, thanks! Also it never hurts to introduce yourself in the appropriate section >>> http://www.thesecurityinstaller.co.uk/community/forum/14-introduce-yourself/
Edited by datadiffusion
Regards
John
Better off with an enforcer for diy at that price and add on as you can afford , wireless though
it does look a bit carp, but the op was looking for a quality product.
14 minutes ago, John Charnock said:
I am thinking Visonic are a better alternative
http://www.visonic.com/Products/Wireless-Property-Protection/Outdoor-motion-sensor-tower-20am-mcw
Any thoughts ?
J
Interesting detector , 8 quad pirs .....
Anyone try one yet
I've used the takex but not wireless
i hear good things about the tower i must admit
Used the Octoquad things as temporary scaffold protection and some early warning type perimeter protection.
They're OK but wireless is only one way, wired option available, good at picking up foxes...
I normally would suggest active IR beams, it depends on what your protecting and the environment tho.
It is for protecting areas of the garden that are vulnerable to access. My logic is to raise an alarm before intruders get an opportunity to start leveraging the patio doors.
