Oyn-x cctv system viewing over 4g - help
Hi, after a stressful weekend looking for the correct app for our CCTV system we have finally found the correct one. So over our wifi we have fantastic viewing but our problem starts when looking over 4g. Please can anyone advise if we have missed an important step in the setup? Thanks
you need p2p, port forwarding or a vpn in place to see your dvr from outside your internal network
Thanks, I'm struggling to do this on the BT home hub 4. Do I need to contact my internet provider?
If you know your BT user name & password, junk their router & use Draytek
Look for port forwarding or NAT forwarding in the advanced settings of your router. Look in the recorder manual to see which ports need to be forwarded and forward them to the local IP of the recorder. To view over 4g you need to have a fixed public IP
You don't need a password for BT btw, login is BT@btbroadband.net, password can either be blank or if not acceptable to router enter 'bt'.
Agreed by the way, ditch the terrible router.
So you need to know what ports your DVR uses , those ports need to be setup in the firewall section of your router by creating rules , then those rules would be applied and asked to be sent to your DVR IP address
You may need to set your DVR to a static IP setting if your router does not allow you to port forward via Mac addresses
took me 2 visits & a couple of hrs to sort the last homehub out. I assume it was FTC
I had a new TP-Link router & a 2nd user Draytek on hand on 2nd visits I intended to replace the hateful POS
I need to amend my T&C's to make pratting with Homehubs or Thompson routers financially viable
We have set port forwarding and now works fine on a BT mobile, until we try to use my Vodafone to view then some how I seem to kick all users off and they can't get back on until I reset the router. Is it a problem with my mobile?
